Topic: Mass Air ? (Read 998 times) previous topic - next topic
Mass Air ?
Can I Use The C&l Mass Air Calibrated For 24lbs On A 19lb Car. Im Eventually Planning To Upgrade But Will It Work For Now.
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
Mass Air ?
I don’t know how well it will run (probably worse) so I don’t recommend it why don’t you just wait till you get your #24s.
