Topic: help!!! need ans quick--MAC h-pipe fitment? (Read 1445 times) previous topic - next topic
alright i found a good deal on a MAC h-pipe (was originally gonna get the summit one) and i need to know if it will fit and not hit tranny linkage or anything. i seem to remember someone here having this huge problem with one, there was all kinds of pics, and someone told him to bend this piece of linkage in with huge pliers! (or is that not so bad? i just dont like the idea of messing with the linkage that controls my trans)
this would be using stock mustang shortys btw. will it fit alright?
thanks!
-paul
I am using a Pypes off road X-Pipe made for a 5 speed Mustang.I had a small problem with shift linkage clearance.I got a hammer and put a flat edge to the linkage side of the pipe.I didn't cave it in,just made it flat.Not enough to hurt performance.I too didn't want to mess with my linkage.Other than that,I've had no problems.i know mine isn't a Mac,but in my own experience,most are designed very similar.Mine is a two piece unit which also allowed me some amount of adjustment.Good luck.
oh ok well arent the x pipes harder to get in anyhow? cause both pipes are angled in very steep to the center right?
well whatever the case that sounds good! i have a couple different rubber mallets and plenty of small pieces of wood and stuff. i had thought about that but i didnt want to hurt the flow. but then again the mustang headers are full of dents! (im guessing thats for the steering shaft and motor mounts?)
thanks vin!!
Paul
You a floor shifter in that 20th dont you? That usually makes it easier.
heheh NOPE!! column shifter.
Mine went on very smoothly.No problems,except for the shift linkage,BUT,my X-Pipe is for a 5 speed car.
Quote from: ZondaC12;116797
thanks!
-paul
That was me... and here's the link to the thread:
http://www.foxtbirdcougarforums.com/showthread.php?t=10125&page=4&highlight=pipe
Oh, and also if you have a k-member brace like the TC's and sports do and if you can get a hold of a ratcheting tie-down strap this little trick will save you a lot of time and aggravation...
