Topic: Tubular a-arms (Read 1493 times) previous topic - next topic
Tubular a-arms
Does anyone know if there are Fox stang length tubular a-arms that are made for use with stock k-member and springs?
I'm planning on getting 17x9 wheels for the front of my 87 bird. I figured if I'm gonna switch to fox stang length a-arms, I'd try to get tubular arms to increase clearance during turns. Problem is, I'm not planning on getting a tubular k-member, or going coil-over.
If I'm SOL on these kind of a-arms, I'll probably get the Ford Racing arms (FMS-M-3075-D) from Summit, and put in SN-95 ball joints, possibly Steeda X2's.
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Tubular a-arms
i have seen them before, but i forget who carried them. your rite tho, most come as a kit with k member for coilovers, but i do rember seeing them somewhere. maximum motorsports has redesigned stamped control arms that increase steering clearance and have new low friction ball joints and composit poly/ruber bushings that are more firm but not bad for your stock arm mounting points like solid poly. might want to look at them, thats what i ended up getting
