Topic: 88TC..many mods...trades????? (Read 713 times) previous topic - next topic
88TC for sale in Lebanon, PA, $3000 obo. May be open to trades.
Lost interest. Getting our of cars for awhile.
Can get pics if needed.
From Carlisle 2006:
http://www.turbotbird.com/Carlisle2006/TC_Pictures/Glenn_Spangler.jpg
under hood before cleaning up
http://natomessageboard.com/uploads/00000017/TCchassis003.jpg
The Bad: Car has an R-title. Not from an accident. the car was vandalized and the stereo stolen. Stereo was worth over $5000 so the car was considered totaled. Mostly broken glass and small scratches which all buffed out. The clear coat is peeling so it will need paint. Two small spots of rust. One in drivers rear fender well and the other pass side rear window bottom corner. ABS does not work, needs computer. No A/C, front sway bar, PS or power seats. PRC shocks aren't very good(great for the strip though). Front bumper shocks have been moved slightly to accommodate the intercooler. Custom work to front metal to fit intercooler. No idea how strong compared to stock. Haven't had any problems with the custom work at all.
The good:
Mods:SDS stand alone, stock unported head, ranger roller regrind cam, Esslinger adj. cam pulley, custom upper & ported lower intakes, SC60 turbo, powerstroke intercooler, 60mm TB, 75pph inj., Walboro 255HP pump, Kirban adj. fuel reg., Bob's header, 3" exhaust, MSD 6al, MSD coil, MSD Launch Control, Spec stage III clutch, Gillis Valve, Weld Draglites, street legal tires, custom through the floor sub-frames
Car has Polk Audio DB separates in all 4 corners. Alpine CD player. Stereo not currently hooked up. Still have stock wheels with good tires for winter. Car has Weld Draglites (15x9 rear, 15x5 front) with MT front runners and BFG radial TA's. Will inlcude Et Streets(26x11) for extra $$$.
I am looking to get $3000obo. for the car with both sets of wheels.
mods: SDS DFI, ported & polished big valve head(1.89/1.59), Solid lifters, Esslinger roller cam #2277,adj. cam pulley, custom upper and ported lower intakes, 60-1 stage III .63 turbo, powerstroke intercooler, 60mm throttle body, 75pph injectors, Walboro 255HP pump, Kirban adj. fuel reg., ATR header, 3" exhaust, MSD 6al, MSD coil, MSD Launch Control, MSD 8.5mm wires, K&N filter,  Spec stage III clutch, Hallman boost controller, Weld Draglites with M/T ET Street 26x11.5/15
