Topic: '87 Anniversary Cougar (parting out) (Read 2735 times) previous topic - next topic
As the heading says. I have an Anny cat I got for parts awhile ago. The car ran when I got it,but it had sat for awhile in a feild and had wiring problems.
 Has nice body,Decent (good) interior.
Let me know if you want pic of something or price.  I'm going to use the doors. All other body parts are there.
 Thanks  Greg
email@ greg@speedydyno.com
Hey there: any chance it has good strut towers, and would they be the same as an 83 T-bird. If so would you be able to cut them out for me, plus what would the cost be. Thanks let me know. may be just the easiest way to repair my towers on my 83 bird
You can check with Eric (coolCats). I would be afaraid if the strut towers are that bad the rest of the car isn't to far behind. Rust is hard to stop.
Just my 2 cents
core support if possible?
Got that fox rash again!
-Resident smartass! :ies:
How do the sunvisors look?
Any chance you will end up with a spare set of door hinges?
Dave
FYI...strut towers and radiator core supports all have Mustang part numbers...those should still be available new.
Paul,  I'll take some pic of the visors tomorrow.
Proto;  I should have a set of door hinges. ( both sides/upper and lower) ?
Hey Eric, How goes it?
How about the plastic map pockets in the doors just below the speakers - are they any good? (assuming your putting your own skins on the doors)
I'll check on the lower door pnl pices. I belive they were spray painted. If I have them I take some pic.
THe  lower door pnl pockets are missing
 The sunvisor look BAD and the pass side is missing.
How about sunroof gearbox and motor assembly?
THe car has no SUNROOF.
IMG]http://i14.tinypic.com/2wbrcqr.jpg[/IMG]
you and your img issues ;)
