Topic: Help with timing!!!! (Read 2317 times) previous topic - next topic
ok i need help with doing my timing. I would liek to advance my timing. But im not sure if im doing it correctly. Ok do you unplug the IAC or leave it plugged in??  Do you unplug the spout connector only or unlplug both teh IAC and teh spout connector? also wats a good advanced degree of timing ?
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
I'm not sure what IAC stands for but you do unhook the vacuum advance when setting timing.  On premium gas most of our cars are good for up to 14 degrees of initial advance.
the spout conectpr os wat you are talking about correct??  also IAC is the Idle air control motor locatced on the tb
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Unplug the Spout only. Set the base timing @ 12-14 degress. Then listen for spark knock.
thanks you lots :)
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
guess you didnt trust my opinion from last night when i told you to unplug the spout and follow that webpage i sent you.
no i trusted you i just wanted a second thumbs up
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Actually the"SpOUT" (spark output) is the connector that plugs into the TFI module on the distributor. Leave that plugged in. There is a 2 wire shorting plug next to it on the same harness that you unplug.
the wire thats hanging near under the distributer correct?
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
THe  spout is the GRAY jumper.
its grey for the 5.0 SO as well?
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
It should be. If not it will be right there. It's just that little plug. Remove it, set your timing and plug it back in.
well the little plug i unpluged was black and it was rigth under the distributer, hanging.  ill look again and check if i see  a grey one.
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
It's the darker grey connector here, with only 2 wires.
thanks so much that was the only plug i seen and it wasnt grey so i was goin nuts searchin the motor for it, thanks again man
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
