Topic: Conventional to Electronic??? (Read 1933 times) previous topic - next topic
Hi Everyone,
I have a 1985 with the factory conventional cassette with premium sound. I would like to upgrade to the factory electronic cassette with premium sound. Would it be plug and play? If not, what would I have to do to make it work? I would like to keep the factory wiring and amp if possible. If it will, what years and models should I look for that will interchange?
Thanks, Binnie
Hi,
If I understand correctly, You want to change the standard digital cassette player with bass/treble buttons (rotary ones) to a Digital cassettes with a digital controls for the bass and treble, is this?...
If Yes, You just have to found a cassette player like You want with premium sound too, and plug the harness on the radio, and it will work...
So pay attention to take a premium sound car equipped radio, I say this because in some cases the premium sound have a .775 volts outputs to drive the amplifier in the trunk.
There a three differents premium sound in the Ford's, one is the oldest (little "rounded" amplifier in the trunk) made of an aluminium with a two square harness with a big colored wires.
The other is a Ford branded too, but a square box made of aluminium too, black or aluminium color, with two connectors, one with a "big" wires, the other connector is a cable of approx 1/4" round shielded.
The third, is a BOSE amplifier, bigger than the second, same size (around 10"x7-8") but 3-4" height, this is the same system of the second one I noted, but more powerful...
The big mistake in that is to put an speaker output of the radio in a .775volts input, this will result on a severe damage of the amplifier, and/or the radio, but more to the amp...
IF You have a factory equalizer in the dash, it's defenitively .775 volts input...
If My explaination is not too clear (My english is so~so), explain me a bit more Your problem...
BUT if You put out a premium sound radio, and put another premium sound radio of the same era, this will be probably okay...
Hope this help.
[SIGPIC][/SIGPIC]1985 Thunderbird 3.8 carbed 57k original, summer car.
1980 Econoline inline 6 300ci 300k, winter/working.
1988 Base Bird finally crushed... RIP.
Dominique,  The Ridiculous, Fordus, crazyous!!!  :birdsmily:
