Topic: C3 to T5 85 XR7 turbo (Read 1143 times) previous topic - next topic
Well I am finally getting around to swapping the C3 for a T5 in the turbo coug.
I have 2.3 bellhousing (svo), T5 from thunderchicken turbo, flywheel (svo), stock fox stang shifter and a fox 2.3 clutch cable.
I believe that I need a manual trans shift boot/plate, dog bone cable and driveshaft.
On the drive shaft which one do I need for the swap.
Shift boot/plate. What years of cars do I need to look for to make the install look factory.
Will the fox stang clutch cable and dog bone work correctly.
kyle
Any Tbird 5spd d/s will work.
The shifter plate would need to be 85-88
The SVO clutch cable set-up will work fine.
drive shaft should be the same.
