Topic: Spilled its Guts (Read 1965 times) previous topic - next topic
Spilled its Guts
:barf: so i go over to tighten my oil filter at onenastybirds house cause my filteris loose and my rubber strap wrench is slipping in all that room ford gave us. so i tighten it and i i go to leave and as we back in to the driveway from the street to turn around im smoking bad, pass it off, then he sees a puddle and i stop then back up in the street and its oil. shiznit! i busted the filter! i must of spilled 4 and a half quarts of 5 on the street.when i took out the plug is must of only drippled in and the filter was almost empty. so needless to say i need to do an oil change. only did one about 200 miles ago. suck but it could be worse. i got lucky i would of heard it over the stereo and i would of passed the oil gauge beep off like i did when it was acting stupid about a year ago. probily would have noticed it before i messed any thing up to bad but i left a river of oil down the street in front of 2 houses. im going over there tomorrow with cat litter cause i dont want to leave it like that i would be pissed if someone did that to me. anyways its going to be a stank ass ride to school tomorrow with all the oil burning offfrom the spray it did all over the driver side of the engine bay. suck but like it says it could of been worse
Spilled its Guts
Wow, I bet I haven't needed a filter wrench on my vehicles in years. I use those fram filters with the rough black stuff on the end for grip. Love 'em. Best invention since sliced bread:grinno:
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
Spilled its Guts
You tightened the filter with a wrench? No, no, no, no. You should only hand tighten a filter otherwise you will crush the gasket resulting in leaks.
Spilled its Guts
if you can get to the end of the filter its fine. Try it on the 84-87 v-6's.  What I did that has worked the best, get an oil filter wrench with a chain. Tighten that bad boy down as hard as you possibly can. Then, either the whole canister comes off, or it will loosen. I had to do that only once. I went through about 4 diffrent style's of wrenches before I finally got one that worked right.
Spilled its Guts
FRAM filter is the kind i busted! i couldnt get it on tight enough and i use the rubber strap wrench so it leaved a small little dent in the end on the side that dont hurt nothin' .
i hate a leaky car so me hand tighting it was not an opption, the strap wrench always work great for me and never crushes the seal.
Spilled its Guts
I've never had a filter leak by hand tightening it.
Spilled its Guts
Quote from: thunderjet302;112439
as said before, hand tighten it.. and back 1/4 turn..... kinda like doing the fron rotors..
Spilled its Guts
I'd stay away from those fram filters....Do a web search you will find out what  they are......motorcraft is a btter choice not only for filter media, but can strength
Spilled its Guts
Quote from: Pressure cooked chicken;112418
Yeah, except the filter itself is junk.
Spilled its Guts
Fram blows, I always tighten my MOTORCRAFT/WIX filters as tight as my greasy hands can tighten them, never had a problem.
Spilled its Guts
If your filter leaks after tightening it with your hand you've got a problem. You should NEVER have to use a wrench to tighten the filter. Getting one off is a different story...
Spilled its Guts
To quote the lid on my case of QS16 oil filters (yes I buy in bulk, PAL rocks)
"tighten one half turn from the point at which the rubber gasket first contacts the engine."
What I alwasy do is pull the gasket off the filter, rub a tiny bit of grease on both sides then install.  On large diesels (work related) this is suppost to keep the massive engines from rattling off the filters during prolonged periods of idleing.  I figgure it cant hurt to do it on our cars either.
