Topic: Balancer (Read 1072 times) previous topic - next topic
Balancer
I just want to make sure of something with a 5.0 balancer/damper. SEFI 5.0s should have a 50 oz balancer correct? I'm assuming that a balancer fom a 5.0 SO is the same as a 5.0 HO one. I can use the balancer off my 5.0 SO on a HO right? Thanks guys, even if this is a stupid question:dunce:
Balancer
Yes
1986 bird, 306, Dart heads, 550 lift cam, exp. intake, 50lbs injectors, 76mm C&L MAF, Procharger D1R blower 14lbs, 3 core intercooler, 55shot ZEX N20, tremec 5speed, 3.73 gears, auburn pro posi,headman full length headers, 3" exhaust
custom chip by 5.8FastCat
[SIGPIC][/SIGPIC]1955 bird 351w, AFR 185 Heads, 580 lift cam, D1R  Procharger 10lbs tremec 5speed, 3.92 Gears
2007 Hayabusa, R-22 pipes, K&N,  Power Commander
192hp
"Imports are like tampons, every p@$$y has one"
Balancer
Thanks :cool:
