Topic: Loose steering column (Read 1373 times) previous topic - next topic
I removed my old steering column that had a bearing issue(had a hard spot that was like a bind in the steering shaft) so I replaced it with a JY one.After install I road tested and it was good except for one thing.The steering wheel is a little loose but not at the wheel?!?Is there anyway to tighten the bearing or whatever is loose there in the steering column?
:burnout:
