Topic: The Fila Project... Wondering why Fila was banned? Read the last few pages (Read 148433 times) previous topic - next topic
Reply #120
*If* I get the E'lan then it will be my DD. Thats why I need to know what is more worth it right now
Reply #121
I just spent anther $103.85 on my brakes. New drums, springs, wheel clyinders, self adjusters for the rear, new pads for the front, 2 chrome breathers and a Mt Dew. If there is anyhing speical I should know tell me before tomorow.
Reply #122
Got by rear brakes done today. All new everything is finally done. Bled them and tested it. I never knew that these cars stopped that well. As last time I only had front brakes. Next project will be Nates headers and H pipe. After that who knows
Reply #123
i read the whole thread,, good work man!!!
comments on things i noticed,,,,,,,,
that intake looks familiar,,,same one i ported on my 306 swap.  You can go look at it on my 306 thread.  I am currently suffering from "lack of time" so its gone no where since last post.  I have to pull the motor again.
you happen to have the CFI with matching intake ports. ALL i suggest you do is grind out the upper half of the cfi so it matches the butterflies.  Also, you have the vac actuated idle control assy which is the earliest version of CFI.  You have blue top injectors,,right?
i see you are exploring hooking up your heater lines to the AC core??
on the flywheel, i wish the ring gear was replaceable on AOD flywheels like they are on Stick flywheels, it would be cheaper i think since the ring gear is only bout 20bux.
In one photo, you have a heater core line that branches off and goes to the intake,,Whats that do? where does it go?
Did you change out the front seal on the tranny?  its like only 2 bux or so.
The engine bay looks a whole helavalot cleaner imho,, did you sand yor valve covers?  looks good!!
I think you need to be gone with that egr and put a plate over it.
to the rear driverside of your CFI, is that sensor your Air Charge Temp sensor?  I decided thats where it should go on my intake as well but i had no example to go by.,,didnt know you had the same intake or i would have asked.
As for converting to carb,, you dont really need to change out the timing cover,, just cut out the plate blocking you from mounting a mech fuel pump.  OR>>>>>>>> purchase the regulator to get your presure down to about 8psi there abouts and fab up ends to feed the carb. I would stay CFI for now if i were you.
Open up the upperhalf of that CFI next,,, you'll see what i mean and if you have trouble removing the screws to split it in half,, leme know.
You have no choice,, your gonna have to grow your tool inventory!! serious man.  Id suggest asking around if anyone has doubles of stuff they wanna sell or get rid of or perhaps fleamarkets so it keeps cost down.  You gotta start somewhere.  Afterall, it seems you have the ambition so get the tools to match:grinno:
Long Ass Post Comin Up
Reply #124
Quote from: jcassity;118866
I think they are blue but are extreamly faded. They look almost light green to me. I'll try to get a pic up tomorow.
From the best I remember ( it's dark out) it goes into my egr spacer and out back into the intake. This is a blind guess and I'll know for sure tomorow
Not yet. This AOD will only be in the car for alittle while longer. I will be building a newer one soon with a shift kit or I may just go 5 speed. Still pu in the air on this one.
Just alittle polishing. No sanding. They look better because all this shiznit that used to cover them up ( Vac lines...) are now gone IMO
A plate? I need alittle help on this one
To the rear driverside of your CFI, is that sensor your Air Charge Temp sensor?
I have no clue
I have my " source " workin on that.
I'm goin paycheck by paychek here. I'm *hoping* that I can blow all my x-mas cash on tools. If not it's off to the flea markets and I'll take what I can get.
Thanks for the intrest bro!
Reply #125
I have no clue
Reply #126
I have no clue
Reply #127
the carb my dad had laying around turned out to be a 700, and my 351 is running a 750 so i can't help u there sry man
Reply #128
Thats cool. I think I have one lined up. Now it's either 2 barrel or Modded CFI
Reply #129
modded cfi. Mike its apart now just gotta pull the screenes clean her up (gonna suprise you on this) and just overall modding it. and you WILL love the changes i do. But now if you had the 4bbl butterflys i could change those for you too. and grind her up. But overall you will be impresed. If its pix you want let me know bro!
Got that fox rash again!
-Resident smartass! :ies:
Reply #130
Thanks John! And will this be my x-mas present or my B-day ( Jan. 6th)?
Reply #131
its looking closer to your bday. But i will do what i can to get her done by the end of this week. but no garentees.
Reply #132
heres a teaser for ya.
Reply #133
Shiny parts for me!!!! How much to ship that bad boy to me bro?
Reply #134
Just found got the camara back, so heres a few progress pics and a few of the questinable dizzy
