Topic: Disc brakes still mushy...prop valve? (Read 2484 times) previous topic - next topic
I was wondering if there is ANYTHING else I can do to make the pedal feel less mushy.
1. 73mm front calipers (Lincoln)
2. 11" front rotors
3. Turbo Coupe rear disc conversion (SSBC Kit, including lines)
4. Big bore SVO master cylinder (including lines)
5. PF Carbon metallic pads
As far as I know, my stock 1988 Cougar prop valve could be my problem.  Is there one from a Lincoln or Mustang SVO that's better?  Your thoughts?
pro-five-oh
simple stuff first.
did you bench bleed the MC before installation?
good bleed and flush on the entire system.
if it comes down to prop valves, i would bypass the stocker and put a manually adjustable one in the rear line.
The stock prop valve will not cause mushy brakes with a rear disk conversion, it will cause issues with line pressure  and flow to the rear brakes though.
As gumby mentioned, did you bench bleed?
Yeah, its been bench bled. I re-did the brakes a few months ago (new rotors/pads) and bled it again. The car stops pretty  good, but I just wish there wasn't a 3-4 inches of pedal travel that doesn't do anything.
I used Valvoline Synthetic brake fluid, I think I'll go back to Ford DOT3 since it has a higher boiling point. I boiled the fluid after 120 miles of open tracking, but I only noticed it when I saw the lower half of the M/C was wet. It never felt bad otherwise.
Quote from: Chuck W;111566
So is there a better prop valve for my setup?
Thank you both for your help.
pro-five-oh
Are you using the stock booster... I remember reading somewhere that you needed to use the 93 cobra booster with a "big bore" master cylinder... Maybe someone else more "in the know" can chime in on this.
One of the disk brake ones would be a better choice, but an adjustable would be ideal.
I never needed the 93 booster when I used the SVO MC...
Yeah I am using the stock booster.  I heard that wasn't an issue either, but you could be right.
Its either the prop valve or the booster. Frankly I'm at a loss to see which one will help more.  I'll cross reference the part numbers for the prop valve and start from there.
pro-five-oh
I thought you were supposed to use a SN95 V6 Mustang booster with a SVO large bore brake master???? , there was a site that had all this info but I can't remember if it was for just the Mustangs or if it could be used on the Fox Thunderbirds too.
:burnout:
FWIW, I'm running a stock Mustang 5.0 booster, SVO MC, 73mm calipers with stock rear disc (and the factory TC prop valve). The pedal has a little more play before it starts to firm up, and it doesn't always feel as firm as it should be, but the brakes work fine so I don't worry about it much.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
an LSC prop valve will work fine.
