Topic: turbocoupe brake problem (Read 1965 times) previous topic - next topic
I am having a problem with the brake pump, it won't turn of even with the car turned off. is there a silinoid or switch that could have gone bad? if so where is it?  oh ya its a 88tc 5speed.  thanks.
Sounds like a stuck relay. I don't know much about the 88 ABS brake setup but I know there is a realy in there. Someone else will chime in I'm sure of it.
I hope so.  some one besides me has had to have had this problem.
mine wont run unless I ground the relay, but then it wont shut off until I turn off the key..  the relay is new from Ford
where is the relay?
the relay is located in the red square.  I think there are two attached but the front one is the one you should be looking at. you will have to take the assembly loose.
thanks ill mess with it tomorrow morning.
