Topic: fuel line difference? (Read 1256 times) previous topic - next topic
From what I've read about 1WildBird's engine swap thread, I've gathered that there's a difference in fuel lines of 5.0 cars vs. 3.8 cars. Just wanted verification on this.
I do know the TC fuel lines are different.
Yes they are different.
I have the V6 lines from the tank on up, with the large feed line connecting to the V8 fuel lines I picked from a yard.  The return I spliced in with the Ford fuel splice kit. Something that isn't the best choice, as others here will say.  Better choice would be to pull the lines from a V8 car from fuel tank pump to engine.
If I had to do it all over again however, I'd like to replace the stock plastic fuel line (which is nearly 20 years old) and go metal tube, or use the fuel lines in the Summit Racing catalog.  There is an adapter that will connect them to the stock fuel rail line connector:
RUS-651104
http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D651104&N=700+0&autoview=sku
that was mentioned in an earlier thread.
V6->V8HO 88 LS
5.0L V8 87 XR7
What didn"t believe me?  Hell I can take ac ouple pics if you want more proof.
The 3.8L lines come out through the top of the inner fender, and the 5.0L lines go under it and up to the motor.
The 3.8L lines are shorter and wont reach.  The pressure line does reach, but there is no slack at all, if a motor mount broke it could rip the line off.  So I lengthened both the lines by about a foot.
I believe ya...just wanted to make 100% sure before I get the stuff i need..:sorry:
1 WLD BRD is right. I'm working on shortening the intermediate v8 steel fuel lines for my car to adapt the V6 lines to the V8 fuel rail. The fuel pressure shrader valve is located on the V8 intermediate line and I want to keep it.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
