Topic: New TCI AOD (Read 1187 times) previous topic - next topic
New TCI AOD
I just put in my new TCI AOD this weekend.
Summit TCI-431000 Streetfighter $1259-
Summit TCI-432700 Saturday Nite Converter $296-
Summit TCI-438000 Deep Finned alu. pan. $152-
May seem expensive but remember I can't get a hold of anything here in Norway.
Rebuilding the old one would mean long time no car.
This one is good stuff, newest case and all the mods.
Guy who had the car before me hauled a housetrailer each summer.
So the old one was mushy slipping and geared up and down, up and down on steep hills.
Been waiting since May, shipment got 'lost i space' before it finally came here.
You guys who want crisp shifts then this is it. In fact its neck snapping hard for a daily driver.
Installation went ok, the usual rusted exhaust bolts etc.
Had to make an adapter plate cause the floor shift wire is now an inch to long, go figure?
A word of warning, the deep pan drain bolt is now the lowest point on the car.
So you who have slammed the car down wouldn't want this.
Some future day with a couple hundre more HP from the stock 5.0 and it'll have some real work to do.
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
New TCI AOD
good work.....sounds great
