Topic: white guage faces (Read 3315 times) previous topic - next topic
white guage faces
Well if everone is having good luck with them then I'll give them a try before I install my buttstuffog guages.
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
white guage faces
How hard are they to install?Also,othr than the boost gauge,are they the same a a Sport model gauges?
white guage faces
they took me maybe an hour to install after I removed the cluster from the car.  I used double sided tape to attach them to the factory faces.  and I installed my on/off switch to the panel under the steering column.  as for being the same as the sport model I am unsure.  but for $20 you cant really go wrong
white guage faces
Quote from: 88turbo;109433
Delete the switch, that is really pointless IMO.
white guage faces
When I pick up the Sport,I think I'll grab a set of these.They look great.Although I'll have to get a stereo with matching lighted face.Oh,and how will I match the clock?I'll get a real clock instead of the digital piece.O.K.,I think I have a plan.Thanks for the pics and info.
white guage faces
Quote from: Ether947;109434
can you do a write up on how to do this?  I have no idea :dunno:
white guage faces
Take scissors, cut wires near switch. Strip the ends and twist together. Tape up. Celebrate. :)
What did you use for a power source? Always on or on when parking lights are turned on?
white guage faces
Yep. I have no idea why that switch is there. =/
white guage faces
i have them as well .i had a minor fittment issue but like 88turbo a little 2 sided tape and all was well.all i can say is they are great for the $$ and i love mine.
white guage faces
The old ones didn't have an on/off switch, I don't know why the new ones do. Mine only has a little  to adjust the brightness, and a switch to select blue or green, but I just leave mine on blue all the time anyway.
Also, I've had mine for almost 3 years, and I've noticed that lately the gauge faces will just randomly turn off sometimes....I have to turn the brightness adjustment  up a ways and they finally come back on, and they usually stay on for a good while...I don't know what makes them do that, they haven't really done it in the last couple weeks. I'm guessin they're starting to  out though.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
