Topic: headlight bulbs (Read 1344 times) previous topic - next topic
headlight bulbs
I'm thinking about replacing my headlight bulbs but have seen some different wattage ones on ebay. What happens if I use high wattage bulbs than the normal 45/65 ones? I reallly would like to use the Silverstar Ultra'a but don't want to spend the $50 for the pair. According to the Osram Sylvania website, their bulbs are 4000K on the temp color scale. I have seen 6500K ones on ebay. What are your experiences and thoughts?
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
headlight bulbs
More watts is more amps. The battery is staying at 12volts.
If you don't want to burn up your switches then put in relays.
Relays will also make them brighter, cause theres less voltage drop  directly from the battery.
I beleive the xxxK temperature indicates color not brightness.
Remember white is the presence of all colors.
Ever seen TV where they dress people in blue and use blue light?
Then you can't see the blue stuff.
BobNorway;)
There are only two tools you will ever need:
1) WD40
2) Duct Tape
If it doesn't move and should, use the WD40.
If it moves and shouldn't, use the duct tape.
