Topic: exhaust question (Read 2043 times) previous topic - next topic
exhaust question
i know this question has already been answered a million times but i couldnt find it so, What needs to be modified for an aftermarket mustang catback system to work. I plan to go with bbk long tubes short x pipe and flowmaster catback?
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
exhaust question
intermediate pipes and tailpipes
exhaust question
relocate the fuel filter
exhaust question
Shouldnt have to relocate the filter if hes workin on the car in his signature(88 Sport). I know i didnt on mine and im pretty sure all the sports came with the fake duals.
exhaust question
Only 83-86 cars have to have the fuel filter moved. The 87-88 cars don't.
exhaust question
No issue with my fuel filter - it's an '87.
I went with 18" lers (Magnaflow makes them) to make up for the 4" longer wheelbase (Mustang uses 14" lers) & LX talpipes with 13" extensions to bring the tips out to the rear bumper.
Looks sweet now :D
exhaust question
I have an '85...where's the recommended location to move the filter to?    I want to fit dual mustang lers.  I'm not sure if moving the filter toward the front of the car a few inches is enough, or if it should be moved to the outside of the framerail, like i've seen on some.  Would the fuel line from the tank to the filter be long enough?
Thanks.
exhaust question
any thoughts...anyone???
exhaust question
out side the rail. is should be long enough but if not just extend it.
exhaust question
How would I extend it?
exhaust question
Just disconnect the filter, plug some barbed extension hose fittings into both hoses and add a few inches of hose on either side, however much you need.  Any decent parts store will have those things cheap.  Oh and don't forget hose clamps.
exhaust question
Quote from: Cougar5.0;109152
Did you use the mustang  intermediate pipes without extending them when you did that ?
SOLD!!!!
exhaust question
Quote from: Master_xzavior;112354
Yes, that was the advantage of using 18" lers - make up for the 4" wheelbase difference & make the car a bit quieter - win - win for me :D
