Topic: anyone ever messed with a blow through carb setup ? (Read 1045 times) previous topic - next topic
fixing to play around with the ranger some and going to do a junk/free setup will be low boost 8-10 psi setup any links to carb mods etc would be appreciated.
i will either use a 2brl ford ,4 brl holley or a carter 4 brl
playin with one right now. its a slant six duster weare puttin a SVO T3 onto with a 390 holley DP. might end up with a bigger carb before its all tuned, but i found this while researchin. hope it helps.
http://www.hangar18fabrication.com/blowthru.html
Quote from: gumby;108778
thanks for the link it will help tons
Well this should be interesting
