Topic: i want to buy a turbocoupe (Read 1582 times) previous topic - next topic
well, im looking to buy a turbocoupe, but i hear they have alot of problems, does anybody know what kind of problems they have? i also want to know how many after market parts are made for the 2.3turbocharged engines besides just bigger turbo's.
Quote from: quicksilver;108419
Problems? lol
There is as much 2.3 lima ford aftermarket support as your local 302:pbb:
there are alot of parts but some need some modification to make fit like cold air intakes.
You dont want a turbo coupe. Take it from me.
If you buy one you WILL need to visit this place.
www.turbocoupe.org
The have a vendor's section, you browse through it for available parts. The TC Specific Aftermarket is actually pretty small. Just like regular ThunderCats, most parts come from Mustangs and are made to fit.
I prefer turboford.net
As for problems, I haven't really had any huge problems with mine aside from the ABS master cylinder going out on me. It's actually been a really good car.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
I would say that there isn't any big problems with the turbo coupe it is just a lack of understanding that there are a picky setup. I love mine it just takes a little getting used to what is really needed to make it run right. As for aftermarket bolt on's there aren't alot but there are plenty of things you can do to make more power than adding a bigger turbo. Also if you are really interested get an older one 83-86 they came with a garret t-3 vs the 87-88 that came with an IHI turbo. The t-3's can make more boost than the IHI can. So you can do more with it before you need the turbo upgrade.
Quote from: Tbird232ci;108438
Bah.
Quote from: ipsd;108457
Well, sort of, there's a limit to how far you can go on the T3 cars since they have no intercooler whatsoever...and I personally wouldn't do over 18 (the IHI's max) on a stock fuel pump anyway, but that's just me.
The earlier cars are easier to work on, but the '87-88 cars have all the "neato" features like the 8.8, 3.55-geared disc brake rear, 16" factory wheels, intercooler (sucks in the stock location but can be relocated), etc.
Also be aware that the engines are not all identical over the model years, there are differences, and the newer you get the better the engines are (as far as the VAM/injectors/intakes/computers go)
Garrett H.
Exhaust sound clip
Another clip
Bah....buy the car you like the looks of and change the mechanicals to suit your desires....
This talk of "this one is better" or "that one doesn't have this" is all irrelevant.  The newest of these cars is 18 years old.....how they came "stock" is moot at this point.
