Topic: Best Year Range 429s (Read 1757 times) previous topic - next topic
I am thinking about dropping a 429 in my cat but I need the best year ranges of that engine. I know some of the later 70's ones sucked.
Any suggestions?
I found this
http://cgi.ebay.com/ebaymotors/FORD-1971-429-2-BOLT-ENGINE_W0QQcmdZViewItemQQcategoryZ33615QQihZ010QQitemZ200034019170QQrdZ1
what do you guys think?
Also, what trans goes the best with a 429. I was thinking C6 but any other suggestions would be great, thanks!
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
It was mainly the heads and compression that sucked them down in their later years which you would most likely replace if you were building it up.
Why not go for the readily available 460?
True, a 460 would be nice. I still like the history of the 429 though.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Find one with D0ve heads.  In '70 they were rated at 365hp, not sure what they were in '71, probably the same.  Try searching on www.fordmuscle.com.
68-71 Imo
Definitely try to find 68-early 71 blocks.  I had a 71 SCJ stuffed into my 68 GT Fastback 'Stang back when I was in high school.  Tough as nails motor!  Or...you could just go and stuff a crate (SVO) 514 under the hood and call it good!  No one would ever know the difference  :)
The future...
...because life is just too short to drive boring cars...
MMMMM cubes taste like chicken.
2004 Impala
i have a 68 429 block,crank, and heads( c8ve's ). block is standard,crank also.heads are stock with no work done to them. i'd take $400 for them.
86 thunderbird elan
86 mustang coupe
Quote from: fordguy;107984
How far away are you from Jacksonville. Because I am about an hour away from Jax in Valdosta Georgia. I am very interested in your offer.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
Quote from: Carl;107989
about 3 hours. i'm an hour north of tampa. spring hill 34609 if you want to google it.
86 thunderbird elan
86 mustang coupe
