Topic: Trans going out (Read 1292 times) previous topic - next topic
Trans going out
I have a 5.0 AOD with a floor shifter and my trans is going out.The only trans I can find are column shift.Will it work in my car? Or what can I swap with.I went to Car-Part.com And show that these trans come from T-Bird & Cougars only.What source can I use?
Thanks
Al Green:cool:
Trans going out
I think you have to flip the shift lever on the tranny upside down for it to work coloumn-floor shift
Trans going out
Quote from: tbirdscott;107242
100% correct.
You need to drop the trans pan and loosen 7/8" nut and rotate shift lever 180*.
Thanks Scott & Kwik
I had a feeling something had to be switched.So that means that park on the floor shift is low on the coloumn and thats way I will flip it 180*.
 Thanks alot.
Al Green:cool:
Trans going out
colum pulls from the front,stick pulls from the rear.
You can make it work.
