Topic: 87-88 tc axle (Read 1170 times) previous topic - next topic
87-88 tc axle
3.73 70k origional miles, redone clutches and fluid  about 3k miles ago. $300 will deliver up to cirtain distance for gas and tolls.
87-88 tc axle
Disc brakes? or drum?
87-88 tc axle
should be disc brakes.
, i sold my TC 3.55 rear for 100 bucks on ebay, but pickup only, and it was stock-not sure on how good the trac loc was...fluid looked decent tho...
87-88 tc axle
its disk. 8.8  3.7s with good traction lock. and iv sold my last few tc rears for 300 lol, i was thinking of selling the cougars 8.8  for 100, but i just towed it and sed it.
87-88 tc axle
Does It have the calipers/ rotors? do you have any pictures of the condition.... I'm in central jersey and may be very interested..
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
87-88 tc axle
it is a complete rear axle, i even left part of the body hard line incase somebody wants to use it for something else. should even still have the abs sensors on it and horizontal dampeners. where in central jersey are you? did you know  our local club has some meets, one of wich is a ford carshow at a dealership this saturday. my club will be there if you want to show up, or better yet, be in the show.
87-88 tc axle
battery in my camera died, but i just took the axle apart  and checked the teeth on the ring and pinion and they are perfect, and everything is tight, not real sloppy like some of them get. no chips  uneven wear, cracks, and the calipers arnt frozen,  but you should replace the rotors and pads. the pads are thin and rotors are origionals, one's kinda  worn from a pad's rivit comeing through.
87-88 tc axle
where is the show this weekend... If it's not too far maybe I'll take the beast out if the weather is going to be nice.... I live in Middleshag county 3 minutes from Raceway Park in old Bridge
87-88 tc axle
How much for everything less axles shipped to 28027?
Thanks
