Topic: Fuel pump install. (Read 5039 times) previous topic - next topic
Fuel pump install.
I used the sock that came with the kit.  the sock that was on my pump was part of the pump.
Fuel pump install.
Quote from: SLEEPER T-BIRD 87;108410
cut the raised triangle out of the trunk floor ;)
BECAUSE YOU WILL NEVER HAVE TO DROP YOUR TANK AGAIN!!!!!!
Fuel pump install.
does anyone know if you can pull the fill tube without completely dropping the tank?  I need to replace the seal but I dont want to drop the tank again to do it if I dont have to.
Fuel pump install.
Quote from: 87badbird2613;112902
that was my idea,, did that bout 3 years ago and so did a couple other guys here.
as for pulling the fill tube,, open the fuel door and youll see how the tube is installed,, and the small single screw on the inner part of the rear quarter holding it there.  IM sure once you look at it you will see how it goes in and comes out.
