Topic: Fuel pump install. (Read 5094 times) previous topic - next topic
Fuel pump install.
today I noticed that I had something leaking from right under my gas door, so I looked up in there and it was coming from the seal where the fill tube goes into the tank.  when I reinstalled the tube I lubed the seal with lubriplate and I thought everything was fine since it went together easy.  is there a replacement seal from ford for this?  or am I just screwed?
Fuel pump install.
If there is one available you better grab the part number off of it. Otherwise post a wanted thread. If you haven't found one by the time I swap my tank out you can have that one. Are you sure the tube is positioned back to the way it was? I've never had a problem with seal... then again, I never lubed it either.
Fuel pump install.
I'm pretty sure that I got it back in there like it was all of the bolts are lined up and it fits properly.  do you think that it might be leaking because of the lube that is still there?
Fuel pump install.
Quote from: 88turbo;108258
I wouldn't think so. Check the seal to make it's seated properly. I've pushed mine in the tank before. =/
Fuel pump install.
If you don't have a idiot parts man at the dealer, the rubber donut for the filler neck should not be a problem. Not sure, but I believe it is the same on most Ford tanks(IE Mustang).
Fuel pump install.
i used this:
F4ZZ-9072-DA FUEL FILL PIPE GASKET/SEAL
Fuel pump install.
cut the raised triangle out of the trunk floor ;)
Fuel pump install.
Quote from: SLEEPER T-BIRD 87;108410
Why would I want to do that?
Fuel pump install.
Quote from: mjbtbrd;108365
i used this:
That part looks up as a Mustang part - it worked for you huh?
Fuel pump install.
yup worked for me
Fuel pump install.
Just one quick question. How did the new pump go in? Since I'm doing a HO swap in the spring I guess I need a new pump for the HO since mine apparently won't deliver enough fuel. Did you use a mustang pump, and how did it fit? I thought that the T-bird pump was bigger and the Mustang pump didn't fit quite right in the tank.
Fuel pump install.
the pump fit kinda funny and I had to splice the wires and heatshrink them but it works and I havent had any problems.
Fuel pump install.
The pump itself is the same between mustangs and thunderbirds.
I have a mustang pump in my car, and all you have to do is go buy the fuel sock/strainer for your car, and its a direct replacement. Like Graham said, you will have to cut and splice the pigtail, since nearly all aftermarket pumps use their own plug, and they come with the pigtail. I do suggest you solder, and use some good heat shrink.
Fuel pump install.
Well time to buy a pump. Can I get the strainer(sock) new at a parts store or is it a dealer only item?
