Topic: fuel cell mounting (Read 1559 times) previous topic - next topic
fuel cell mounting
how do you get it to sit flat in the trunk when there is a big hump in the floor?
i bought a 12 gal Jaz plastic fuel cell with a 2" rear sump. if that helps.
1979 Ford Fairmont
[/B]
fuel cell mounting
cut out the floor and weld in a flat piece or shim up the low sides
fuel cell mounting
Quote from: tbirdscott;105343
ive thought of that, but..... shimming one side would not allow the fittings to go underneath the floor for the sump. and cutting out the "hump" would lose the rigidity of the floor. or would this not affect it?
1979 Ford Fairmont
[/B]
fuel cell mounting
Quote from: 5ohbird;105363
If you weld in a flat piece you shouldnt loose much, get it bead rolled or tack on a couple strips of 1/4" angle iron if you are worrried
