Topic: engine swap help needed (Read 1131 times) previous topic - next topic
Well I have my car for sale but if it dont sell im gonna put a carb engine in it. Right now it's a 5.0 and I was thinking about putting a 351 or a 350 in it. What will I need to switch out if anything to put this engine in? I know that i can bypass the computer stuff by just not hooking it up. (at least on my other cars I could)
Hood clearance can be an issue depending on the intake and stuff you choose.  I think you can buy lowered engine mounts to drop it a little.  A 351 has the same transmission bolt pattern.  And you can buy 351 conversion headers for the fox body to adapt the exhaust system.
Please tell me you won't put a 350 in it :beatyoass:
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Quote from: firstbird;105231
Well, first off, what year is your car?
If it's an '88, get a speed density eec from an 87-88 mustang gt, or LX 5.0, and the engine, as well. drop it in, fire it up, and go.
Don't forget a good dual exhaust, too. Think Stang H-pipe, and 2-1/4" pipes.
Lastly, you'll wanna put deeper gears in that 7.5 rear, or toss it altogether for an 8.8, either out of said Stang, or get a Turbocoupe (bit more work).
Also, don't forget a good tranny cooler, or at the least a flush n' filter replacement.
As for a carb 351w, well, some will say you don't have to, but I've read it's best to drop the tank, and put a regular (non EFI) sump in, the fuel lines will be a bit of a PITA, and you'll want to get the windsor/fox swap pan...up to you hoss, but i'd go with a decent 5.0, myself.
and as for a chivvie 350...i got a boat, but need an anchor, how much for the chevy jun..i mean engine?? :grinno:
:pbb: 350???
