Topic: 3.8L Fuel Line to 5.0 Fuel Rail Adapter (Read 2015 times) previous topic - next topic
I'm doing a 3.8L to 5.0L swap. What did you guys do to adapt the 3.8L fuel lines to the 5.0L fuel rail?  My 3.8L lines enter the engine compartment through the passenger side fender and I believe the fuel lines on the original 5.0L equipped cars enter the compartment on the underside the passenger frame rail .
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
On my '87 LX I'm planning on using braided stainless hose with springlock to -AN adaptors at both ends.
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Actually, your car being an 88 you can just plug your fuel lines in where the metal lines that connect from below do on the rail.  Only problem is you will be eliminating the schrader valve.
