Topic: Shift cable bracket needed..... (Read 1077 times) previous topic - next topic
Where would I find a shift cable bracket (bolts to the tranny and holds the cable in place) for a 5.0 AOD equipped '88 T-Bird?the Turbo-Coupe and Mustang parts don't work.Anybody have one or know where one is?Thanks.
I've got one here I could let go for $10. Email me at jblank351@comcast.net or call me at 615-907-0535
E-mail sent,thanks.
You know when I pulled the tranny out of my 88 it had that bracket on it even though it was a column shifter car.  And I've seen it on more than one column shifter car at the junkyard.
I'd check into that,but there are no Foxes around here at the present time.I check every week at the local yards.I have the cable to replace the wrong one I'm using now,and a new shifter to replace the one I'm using that I had to modify to use the current cable.It'll be nice to see the current parts go.I can only shift as far as OD.I can't manually shift into Drive or lower.I'll be out this week lookingfor parts.I need to gather some E-Bay parts for selling anyway.Thanks for the tip.
