Topic: h pipe disaster i need help (Read 3136 times) previous topic - next topic
ok guys i was putting on an h pipe i bought liek 1 month ago that came froma  1990 mark vii that had an ho. does that h pipe fit a 1988 thunderbird??  cause i tried putting it on today and one side didnt reach and couldnt fit and i also have bbk shorty headers on . someone help!!!!!
[SIGPIC][/SIGPIC]5.0 Standard
REBUILT MUSTANG AOD
Magnaflow mustang exhaust
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
It should fit like a glove.The 'Bird and the Mark VII are the same in the front end,inner fender,front subframe area.Are you using the mounting "rods" that slip into the bracket that holds up the H-Pipe?If so,cut them off.I used my Mark VII H-Pipe with BBK shorties with absolutely no problems.I replaced it with an off road X-Pipe and stored the H-Pipe.There's got to be something that is keeping the pipe from mounting right.Check and see if the pipe ishiznitting something.Do you have a column shifter?
yes i have a column shifter. if i cut off the 2 hangers how will teh h pipe hold to teh tranny??  yeah but it fits on one side and on teh other drivers side it misses by 2 inches . what do i do im so pissedd arrrgggg!!!
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Where is it not reaching at?  Won't the H-pipe reach up to the headers?
The h pipe wont reach the headers that the whole problem. i dunno wat to do.The h pipe only reaches  to the passenger side and the driver side misses 2 inches. wat to do??
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
The headers and tailpipes can support the H-Pipe.Mine did for years.There's something strange going on here.The Mustang aftermarket shorties are a direct replacement for the factory headers.What year was the Mark VII?Are you sure it was an H.O. car (LSC)?Is the H-Pipe hitting the shift linkage at all?Perhaps binding somewhere?If the hanger is causing the problem,cut them off,or at least the one on the side that is giving you trouble.
If it wasn't a HO car, it wouldn't have had an H pipe and dual exhaust would it?
yeah it was an LSC and it had an ho it was a 1990 . could it be cause of the motor mounts?? cause they are not original. what can i do and its not hitting the linkage.  im lost
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Take a picture if you can, it might help us figure out your problem
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
As I stated,my Mark VII h-pipe bolted right up to the Mustang factory headers I was using,then right up to the BBK's I'm using now.Is it the hangers that are holding you back?
 Oh,by the way SSX,good point about the exhaust.I had thought about that after I posted,but was too lazy to go back and edit.
did you separate both sides of the h-pipe before trying to attach them (loosly) to the headers? othrwise it can be nearly impossible to line them up.
Hey bud, as stated already, if the two hangers are holding you up then cut them off. They serve no real purpose other than to aggravate you. The headers and tail pipe section will hold it up no problem at all. Hope that helps...
85 TurboCoupe. 306/DartSr's/Vic 5.0 Intake/B-25 Cam/Vortech YS trim/A9L Computer and Mustang Harness/ Pro M 77 MAF-50lb inj/TKO/15X10 Prostars/MMR Coilovers-90/10's-50/50's Chucks shock brackets/CHE Adjustable uppers/lowers. FR manual rack/steering shaft.
92 LX Coupe 306/Gen VII DFI/ No engine /TTI Race kit T-76/Comp cam/ 15X10 Prostars
i dont think teh hangers r givign me a problem its that one ends reaches and one doesnt . im thinking its the motor mounts maybe there too high? hey ETHR947 what you mean seperate teh h pipe it comes apart????  dont i ned to weld it back??
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
Is the H-Pipe level?Meaning,is it turned towards one side more than the other?If the H-Pipe came off of a car with headers,then that tells you right there that it's not too short.It's either the headers,or you have it hitting somewhere,or twisted to one side.Cut the hangers off,and loosely fit it to the headers.If you have your smog equipment,perhaps you're bumping the tube to the exhaust,or the frame (tight on the passenger side),or,the shift linkage is in the way when you're trying to push the pipe up tp the header.Do you have a factory set of headers?Check the headers you are using to the OEM headers and check for length (size and shape will be a little different).
well i got the headers off of cougarman which are bbk shorty headers
REBUILT MUSTANG AOD
BBK shorties
mark vii h pipe
BBK intake
KYB shocks , struts
moog springs
