Topic: 87 tbird biggest wheel/tire combo (Read 8308 times) previous topic - next topic
hey guys im new here! killer site. let me ask my question and then ill tell ya a bit abotu the project.
what is the biggest tire/wheel you can fit under an 87 tbird{non tc- has no quad shocks} without minitubs? i have seen 10.5 meat on 10 inch rims on fox mustangs. i have been told the t bird isnt the same fox tho. from messuring the wheel well it doesnt look like a big hammer will make a 10 inch rim fit without any tire on it. can i atleast get away with an 8 inch rim with a 325/50 radial or something of that nature?
the project is 521 ci bbf {250shot of n20} on my little sleepy bird:evilgrin:  haha. body work leaves much to be desired. has no interior {make her as light as i can, hopfully under 3k with me} gunna be my little sleeper. looking for low 9's on a full spool with 4.10's {9'' read} and either a turbo 400 or a glide. ill get pictures up threwout the build. i have the bottem end, the block, heads and my 750$ tbird find.  thanks for your time fellas.
i just recently swithed to 275/60/15's on the rear. and they seem to hook better then the 295/50/15's i used for years.. i was able to fit a tire like a 295/50/15 because i used a fox body mustang rearend.. it bolts up at the same points as the Tbird/Cougar. but the axle tubes are 3/4" shorter on each end.. and just so you know the T/bird/Cougar wheel wells are larger then mustang wheel wells..
and i used those tires on stock 15/7's and weld draglites 15/8's
and i'm going back to the stock rim soon with 275/60/15's mounted on the rears..
i know meny people that owned fox body mustangs and 275/50/15's just fit and rub just a little on the outer QTR and to fit. 295/50'15's you have to beat the death out of the inner QTR to get them to fit. and will still rub a little..
check out http://www.coolcats.net/catjam/
and you should see more picks of my cougar with the tires i stated on my car
and other cars with diffrent tire sizes
Nick
weld pictures
thanks abunch for the reply and pics nick! any one else got some experience for me?
the first pic is a 275/60/15 on a 15x8 weld draglite- turbocoupe disk brake 8.8
the second pic is a 275/50/15 on a 15/8 draglite with a mustang 8.8
i have seen guys with 325/50s on draglites but im not sure the exact offset
275-40s on 17x9 imitation cobra r's (fox mustang offset) in the rear with no rubbing issues at all.
Im fixing to put a 325/50/15 under my bird on a 15x10 with a 6.0 backspace. :pbb:
i had a 17x10.5 on the rear before with a 315/35/17
Are the tires going to stick out? If it all tucks in it should look great. Post the pics...
85 TurboCoupe. 306/DartSr's/Vic 5.0 Intake/B-25 Cam/Vortech YS trim/A9L Computer and Mustang Harness/ Pro M 77 MAF-50lb inj/TKO/15X10 Prostars/MMR Coilovers-90/10's-50/50's Chucks shock brackets/CHE Adjustable uppers/lowers. FR manual rack/steering shaft.
92 LX Coupe 306/Gen VII DFI/ No engine /TTI Race kit T-76/Comp cam/ 15X10 Prostars
Quote from: 87badbird2613;102795
Do you know the offset of those rims with the 275s?
Quote from: Uncleford;103163
Dont have any pics yet waiting on the wheels to arrive. Hopefully this week.
Quote from: 88sportcoupe;103170
5.5 backspacing
Who is still manufacturing 275/50/15's? I'd be really interested in getting a set for my cat to last until the big work starts next spring.
87badbird2613 please post what you did to modified your rear taillights. Their wicked! I have a spare set that I'd like to do the same with. Thanks
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
I've only got a few tire lists here, but... BFGoodrich Radial T/A
Here's one (if it works): http://www.customwheelsdirect.com/tires_brand/BFGoodrich.php?PHPSESSID=8709f171fb71140525965469925a2ab6&brand_path_file=BFGoodrich.php&tire_w=275&tire_h=50&tire_d=15&pricerange=all&search=Refine+Search
After a couple hours of googling I found the T/As. Tire Rack has them for $106. Also found some spoogeho 295s for $72. Only SR rated but I only intend them to get me through the winter.
