Topic: Wrecked 87 5.0 Mustang (Read 794 times) previous topic - next topic
I am parting out a totaled 87 5.0 Mustang GT.  I should never have sold my 87 turbo coupe :(
Rebuilt t-5 with under 2,000 miles, everything else needed to convert to manual esides shifter (pedal assembly, bellhousing, Ford Racing King Cobra clutch, dual exhaust crossmember, etc.) - $650obo
5.0 HO EFI, 130,000 miles, minus water pump and crank pulley, and power steering pump, strong runner - $300 obo
15:1 steering rack - $50 obo
smog pump eliminator for 5.0: all aluminum, less than 3 months old, -$40 obo
190 lph BBK in tank fuel pump, replaced just after i did the transmission, -$75 obo
255lph high pressure walbro in tank fuel pump with install kit, never used - $100 obo
mustang articulating sport seats: adjustable bolsters, lumbar support, thigh support, no twist in seat back, grey, good shape, seat back latch for rear passengers is broken - $100 obo
8.8 rear axle from same car, needs trac-loc rebuilt, i think it has 3.08 gears but may be 2.73
other fox parts available (turbine wheels, etc)
I am in flint, michigan for the next three weeks.  After that i will be near rochester, NY, where i have more parts, including 35lb/hr injectors from 87 turbocoupe with fuel rail, stock pressure regulator and pulse dampener)
Are you willing to part the engine out? I need the a/c comp. bracket , p/s bracket and alt. bracket.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
For any pictures of the car, or any of the parts, email me at rall2899@kettering.edu.  If there are any other parts you might be interested in, feel free to ask.  88BlueBird, i sent you a pm.
