Topic: WANTED: 87-88 bellhousing for t-5. (Read 1191 times) previous topic - next topic
Need one so I can swap in a turbo/t-5 in a ranger. thanks. 831 383 0412
This belongs in the wanted section.
88 TC, Lots of Mods.
Indeed it does
We're selling a T5 bellhousing we took off of an 87/88 Turbo Coupe for $25, plus shipping.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
nice FLST. You are? Why Do i need this exactly? I mean, I have a t5 (from an 85 tbird) I am putting in my 92 ranger. Does it fit better? And also, does the bellhousing come with the hydraulic stuff needed to convert my cable clutch t5 to hydraulic?
Um, I saw a Wanted post asking for an 87/88 T5 Bellhousing, so I replied saying we have one. Ours is a hydraulic bell, but it's just a bare bell, no fork or anything. If you already have a T5 w/a bellhousing on it, then you probably don't need ours.
Quote from: hundreddollaranger
All 4 cyl Fox bodied 5-speeds were cable clutch operated, except for '87-'88 TC's.  As stated above, if you've already got a T5 and bell housing, you can just dump it into you're Ranger and have a cable operated clutch.
If you want hydraulic, you'll need a conversion kit.  This consists of the following parts from an '87-'88 TC:
Bell housing - it's a little different for hydraulic
Pedal assembly
Clutch master cylinder
Slave cylinder and resevoir
Associated lines
hmmm...
My ranger is hydraulic (stock) and the tranny is bad. I am putting a 2.3t and the t-5 tranny from a 85 tbird (cable)... so I do need a conversion kit. Was thinking (thinking) of adding the clutch cable to the ranger... But that means I have to fabricate something, and I really don't want to do that cause I'm not good at it. A conversion kit? where do I get that....just by getting a bellhousing (and its hydraulic internals) from an 87-88 tbird. Dude...thanks for the $25 offer... I'll keep you posted as soon as I know what I am doing/needing. Thank you.
