Topic: strange misfire... (Read 2405 times) previous topic - next topic
strange misfire...
i have a misfire    like the car is slightly sputtering from 1000 - 2000 rpm only under light throttle ..  if i stomp on it it sputs for a split second then shoots like arocket.. only and slight throttle between 1-2000 rpms    any ideas..  i think my pugs are fouled and maybe i need a hotter plug any suggestions...
strange misfire...
Clean IAC?
Otherwise plugs wires cap and rotor...
Maybe a vacuum hose has a cut or is split?
Just throwing some stuff out there.
I can't remember, is your car converted to mass air?
If so it's most likely the metal probes on the sensor that need to be cleaned.
strange misfire...
what fred said..
i'd go for the ignition stuff
strange misfire...
i think its my mass air meter....
strange misfire...
Two days after your post, you probably already did this but just in case..
Remove the sensor from the housing. There are two delicate metal bars that take the reading that kind of look like two trapeze bars. They should be shiny metal but will look dull gray or black if they are dirty. Take a little bit of rubbing alcohol on a q-tip and gently clean them. It works wonders.
My car gave me fits because of this for 3 months before I figured out what it was and how simple to fix.
strange misfire...
After you've made sure the MAF is clean:
1.) Check your plugs.
2.) How old are your wires too?
3.) Your tps voltage at idle may be over 1 volt as well.
strange misfire...
mine was a MAPsensor vaccum hose. car has never ran this good since ive had it.
it did the same thing plus idle surge and shifted hard and jumpy
strange misfire...
ok gonna try the qtip thing....  i think that might be it...  plugs might be fouled but i dunnno,,,,  wires are nw  and tps is new
strange misfire...
Be very gentle while cleaning those MAF wires.
strange misfire...
Run Codes
strange misfire...
well i cleaned the mass air meter and got nothing ,,,,  still does the same thing ,,,  i think its the plugs  what do you guys recomend  should i have a hotter plug or something,  i do have 24/lb injectors.  gimme your opinions  i have autolite double platinum ap25 in there now
strange misfire...
I'm running 26's,I don't know if it will help you or not.
But if you take them out do a compression test,so you can eliminate a mechanical problem.Maybe to tight of valve,you will know more when you see the plugs.If ones fouled you will no pretty much witch cyl.might be giving you a problem,seems more like a small vac leak.possibly
strange misfire...
Oh yeh did you run codes?
strange misfire...
no codes yet  didnt run
strange misfire...
Quote from: kitzdnm
compression test is fine in all      im gonna change to 26s and change my fuel filter and see what happens  i dunno....
what engine r u runnin
