Topic: Chuck's '83 TBird (Read 101369 times) previous topic - next topic
Re: Chuck's '83 TBird
Reply #480
New pump is installed, but the car runs like doodoo. :nonchalance:
It appears to be super rich.  When I pulled the fuel pressure regulator reference hose off of the intake, the idle smoothed out a bit.
I didn't get a chance to check the fuel pressure yet, but should be able to tomorrow. Hoping that I didn't somehow pinch the return line between the tank and the body (would be hard to collapse it though.)
I'll need to toss the laptop on it, to see what the WBO2 is showing.
It's possible that if the fuel pressure is correct. the car was tuned under a weak fuel supply and now that it's getting a healthy dose, the tune is off. This thing doesn't "learn" like the stock EEC4 stuff.
We'll see I guess. I don't think anything else broke/failed when the pump went.
Reply #481
OK. Got it sorted out.
Tested the fuel pressure and it was good. No need to drop the tank to find a pinched return.
I hooked up the laptop and started to look at things. Almost immediately I saw the MAP gauge stuck at "100 KPa" or ambient. It wasn't reacting at all. SO I grabbed a length of vacuum tube and bypassed the in-situ feed to the ECU and sure enough it was reading properly.
The MAP signal hose to the ECU had gotten pinched when I reinstalled the seat after chasing the power issue.
Found the problem and put it all back together and the car is much happier.  :toothless:
Now, back to my other project and hopefully I can get the roof wrap sorted out soon.
Reply #482
Finally got the roof wrap sorted today.
Some folks may hate it, but I think it's fun. :toothless:
Reply #483
Is it weird for me to say that I like the look from the side more than from the top?
I think that is cool and something different!
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
Reply #484
Chuck, do you have a matching kilt for that roof?  :rollin:
That is totally unexpected. I'm kinda digging it...certainly not as boring as flat black or any solid color for that matter. Great job man!
Reply #485
Lol!
No matching kilt, but I do have a couple others.  I need to put some padding on some of the cage bars in the rear, and I was thinking of getting some matching material and seeing if my wife would whip up a few covers that match.
Reply #486
Man I think it fits the car perfectly!  I also think the shot from the side does it more justice than from directly above.
Reply #487
Thanks!
The side view is obviously a bit more subtle, and tartan isn't some glaring contrasting color.
The GLI Recaros in it have little hints of red in the inserts, so it kind of ties together a bit.
