Topic: Oh Freakin No!!!!!!! (Read 2390 times) previous topic - next topic
Well Today Sucked I Spent All Day Trying To Tune My Car Up Trying Diff Carbs Rebuilding Them And Trying Timing Every Thing I Could Think Cause I Dont Feel Like I Am Getting The Full Pontential Of It So I Got So Tired Of It I Pulled The Heads Because I Had A Hunch One Was Crack Or Leaking In Water Or Something And Sure Enough I Had To Tear Down The Top End Of My Motor With Only 17 Miles On It Water Was Coming In Through The Wall On The Intake Port I Am So Pissed This Blows
I Have A Set Of Stock E7's That I Am Going To Use But I Debating On Porting Them Only Because My Buddy Had A Set On His Mustang And Ran The Same Time With Them Stock And Then With Them Ported What Are Your Guys Take On That I Will For Sure Cut The Bumps Out Of Them Tho
Sorry Just Had To Vent A Bit
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
likely you are not going to see gains on a stock engine.
just because he didnt run any faster doesnt mean he didnt gain anything. porting the stockers may not put down much HP itself but it will help support other aftermarket stuff. they E7 heads flow fine weather they are ported or not on a stock engine. the gains happen when you throw in induction and exaute. couldnt hurt porting them if you have the time and motivation.
~John~
lol, capitalize every word... must be frusterated.
Better then the super pissed ALL CAPPS
Actually When I Type In Caps Lock It Changes It To What You See I Dont Know Why And My Buddy Had It On His 347 And He Was Running 13's And Every Once In A While Would Go Into The High 12's But We Will See What Happens And I Really Dont Have The Motovation To Port Them Ha Ha I Will Let You All Know how It Goes
AN OFF NOTE AFTER HE SWITCHED TO AFR'S HE RUN IN THE 11'S CONSTANTLY
Every word starts with a capital & no punctuation - yikes!
dood, why not just turn caps lock off. that  is so hard to read, the only thing i got out of that was carbs, e7 and 347.
The reason your caps lock disappears is because I set the board to do so. The board will automatically remove caps lock because most people consider all caps to be rude, hard to read, and just plain annoying. I hate it almost as much as I hate spam (and boy, do I hate spam). If there was a way to set the board to remove the first-letter-capitalized thing I'd have done that too.
As you've discovered, the caps-lock undo thingy can be defeated by holding down the shift button. If somebody wants to hold the shift button down to get the all caps effect they can be my guest, but I can rest comfortably knowing I made it more difficult for them to SHOUT :D
Quote from: Thunder Chicken
:cheers: :bowdown: :D
Yeah.. and furthermore typing in all caps and no punctuation really deters people from reading what you have to say. And that leads to off topic discussion about grammar such as this and not really addressing your problem. So you can do everyone a favour and type in a pleasing fashion and your problems will be solved (both grammar wise and whatever topic you're discussing)
WaT U MeEn iT Is AnNoYiNg WhEn PpL tAlk lIke diS?!?111
*chanting* Spam spam spam spam spam spam spam spam.. :p
Would you like some spam spam spam spam spam spam eggs and spam? :p
(Oh, what would Spam be without Monty Python..?)
Wow i didnt think that it bothered poeple like that. I just figured caps lock was cruise control for cool ha ha just kidding. Usally its on because i type my passwords and screen names in caps but, sorry for the big letters.
Oh yeah and i didnt hold down shift i just edited my post and caps lock was on.
Is this writing up to par for every one?
Just kidding you all thanks for the constructive critisisum but, can we get back on the subject to port heads or not. Is it worth it? I always thought it was but after that expirence i second guess when i think about it.
Quote from: Bird351
But I don't want any spam! :(
Grind the thermactor bumps off the exhaust & clean the ports up - maybe match the ports to the intake. I wouldn't do much more than that as you can cause my harm than good if you do not port for a living.
