Topic: Relay ? (Read 4648 times) previous topic - next topic
Relay ?
I do that by doing this from softtouch or do I do something different. I have a freind helping me with the starting thing but what about the pumps?
The six pin connector behind the headlight only has the R/LB wire to the starter solenoid.
The connector on the transmission crossmember is a four terminal connector.
The four wires at the transmission connector are:
1. R/LB from the ignition switch Start position.
2. W/PK D From the neutral safety switch. (Trans must be in Park or Neutral)
3. P/O H From the ignition switch Run Position.
4. BK/PK From the back-up light switch. (Trans must be in Reverse)
A small probe that will slide into these connectors alongside the wire is best for this kind of trouble shooting. You may have to fabricate something.
Relay ?
Thanks chuck, I'll get a jump on it as soon as I get home today. I'll try to keep you all posted
Relay ?
mike one of these days when i get done with work on fri ill have to load the truck up with all my tools and come ehlp ya out with the car. cuz its tough not looking at it to know what is actually wrong with it. But ill dig into my wiring diagram to maybe see what the issue could be. and yes keep us updated bro.
Got that fox rash again!
-Resident smartass! :ies:
