Topic: Two. whole. hours. (Read 3711 times) previous topic - next topic
Two. whole. hours.
then you enter the rear ratio, drive gear teeth (7 for an 88 AOD), tire height, and click "calculate" and it gives you your number.
Do you have a Mustang AOD? They had a 7 tooth drive gear. The Tbird/Cougar AOD has a 8 tooth drive gear. I used a 21 tooth driven gear in my Tbird with 3.73 gears and it was about 9 mph off beacuse I have a 8 tooth drive gear. It would have been dead on with a 7 tooth drive gear. I have a 23 tooth driven gear on there now and it's only about 3 mph off. I guessing that with 3.55 gears and an 8 tooth drive gear you'll need a 21 tooth driven gear.
Two. whole. hours.
You mean to tell me that Ford actually built a difference into the transmissions between Mustangs and T-Birds, as well as a difference from 89 to 90 (in Mustangs)? I suppose this shouldn't surprise me, given Ford's track record for such things. I'd just like to know why in the hell Ford would make a different output shaft for Thunderbirds. My car has its original AOD tranny (for now). You sure the T-Bird has eight teeth? If that's the case I guess you were right with the purple 21 tooth gear...
Two. whole. hours.
Yep my tranny has never been out of my Tbird and it has a 8 tooth drive gear. Don't ask why Ford built different AOD's for the Tbird/Cougar and the Mustang. I know Mark VIIs and Mustangs got the AOD with 7 drive teeth and the Tbirds/Cougars/Crown Vics ect got one with a 8 tooth drive gear. I think it's because the Mark VII and Mustang tranny's had a few extra clutches or something. That dosen't make any sense though because the drive gear dosen't handle power.:screwy:
