Topic: Pretty wheels! Now tires? (Read 4193 times) previous topic - next topic
Ive been meaning to ask this for the past week, but I just didnt have the time between friends visiting on vacation and working on stuff around the house.  Lots of stuff...  I just dont seem to have as much free time anymore...
Anyway, this weekend I am heading up to Casper to visit a friend of mine that has access to a pretty nice shop.  I am going to take my 16" snowflake wheels and bead blast them to clean them up and remove all the old clear paint that is flaking off.  After I get them cleaned up I want to paint the recessed areas black and I was wondering if anyone had any experience painting aluminum wheels.  Will normal spray paint work if the can says it will bond with metal?  Should I clear coat the black/bare aluminum after Im done to protect it or would that just flake off easily again?
My friend also said that he has a set of nice Subwoofers and a fairly nice amp that he doesnt want anymore and that he would give to me.  So I may finally have a better sub that doesnt have to sit right behind the passenger seat!  Woohoo!
I had my turbines blasted and i was planning on leaving the lip polished like the XR7 wheels but the sandblaster screwed it up and pitted the hell out of my wheels.  Anywho back on topic you can use a self etching primer, in a spray can, and some good spray paint to ge the job done i have had mine for about a year now and they still look good save for the scratches and chips that come from driving the car every day.  Just make sure you use a tame media to blast em then mask off what you dont want painted then prime a coat to cover you may need two then spray 4-5 coats and you can clear over the paint but im not sure how well it will stick to the bare aluminum you may have the same flaking problem, but then again maybe not if they are clean, like super clean.
2004 Impala
Here's what I did to my ten-holes and will be doing to my sowflakes as well - it came out PERFECT. The wheels look better than factory new IMO. Anyway, my link:
http://www.foxthundercats.com/tech/wheelrestoration.htm
I may go a step further and polish the snowflakes, but not sure yet. I like the polished look, but then they dont match the center caps...
ROFL!!!  I just pictured the scene from Ferris Bueller's Day Off and just about died laughing.  I will definitely give that a try after I bead blast them to get the clear coat off from the recessed areas.  It looks really nasty in there and is next to impossible to get the clear coat off by just using a brush.  I plan on using some glass beads for blasting if I can get my hands on some.  Otherwise I just plan on being very careful.  ;)
Well assuming that the fires up around Casper Mountain dont burn anything down I will be getting started on my wheels on Saturday.
You can see how nasty they look after sitting in a junk yard for who knows how long.  I think this one is one of the better ones too.  I will try to get some during and after shots for you guys also.  If things go well I will be hitting the local bars early with my friend. :drink:
Lmao that is funny not a bad idea tho glass is the way to go but you still have to get the fine crushed stuff to do it right aluminum is a pretty soft metal and will be pitted if you use too harsh a media.  Oh and i've always wondered if anyone has ever tried knocking down those fins in the holes might give the wheel a cleaner look.
2004 Impala
Quote from: capitlj
I have actually...but i'm afraid it would look like  when done.
I might photoshop one, and see what it looks like.
Quote from: FordTruckFreeek
I'd go look for a stray single snowflake at a JY that might be bent or some other  and experiment.. i think if you used a porting kit for aluminum heads that it would work rather nice :D
The only Snowflakes i've seen at any JY around here...are on my car now...no way i'm messin with them, they're perfect except for some refinishing needed, and one centercap with a small dent. :D
Still looking thru my pics for a decent close in shot of a snowflake...anybody have one i can "borrow"? :giggle:
i dont know if you are still looking suggestions but if you are going to sand blast them or media blast them they make a compund that is like crushed up peanuts and other stuff that is suposed to be pretty gental
and any time you are going to paint bare aluminum you are going to want to use self etching primer
 and if you plan on leaving the lip or any part of the wheel bare i would suggest polishing it real shiny like then using some brake cleaning to clean it up real good (not oil based and dosnt leave a residue) then put an adhesion promoter then spray some clear and wala always shiney aluminum with very little maitnece
i know i lot of stuff but but that will insure that it looks good and last a long time
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
Quote from: Sprayingsmooth
that be walnut shells :D
Thanks for all the help guys, I left here on Friday evening for Laramie and I left in such a hurry that I totally forgot to put the wheels in the trunk. :nutkick:  What can I say?  I guess I just suck at this game.  lol.  So I guess I will be sanding them by hand now.  I did manage to get some pretty sweet stuff out of my trip anyways.  But that is something for a different thread.  I will get some more pictures of the snowflakes when I get some progress made on them.
Original condition.
After paint stripper and some sanding.
After painting and final sanding.
It dropped from 85 degrees yesterday to about 55 degrees today, and it was pretty windy.  So after just an hour of sanding my wrist was sore and all cramped up.  But I thought I would share the progress I have made.
wow, those really cleaned up good.
I'll do mine sometime...
looking good they are going to look great on your car when there finished
