Topic: Used roller cams (Read 1493 times) previous topic - next topic
Used roller cams
I could get into that.  I was actually part of the Thunderbird club but I kinda drifted away from it.  Come to think of it your car looks kinda familiar, are you a member?  My car's still a bit rusty around the edges but I wouldn't mind a chance to show it off a bit.
Used roller cams
SRBird, I personally have about the same set up as you(in a 88 sport) and I use the crane 1.7's, 87 HO cam, on e6's with no clearance problems, but no engine is the same so I would check
Used roller cams
Sum_weirdo I thought yours looked familiar as well. Yes I'm in the club, I'm the one that took most of the Grills & Tails pics found on the web site. Try to make it out to the Show n' Shine. It seems the weather may hold out for tonights cruise night so I'm going.
Flipnbird Thanks for the reply. I plan to change the valve springs as well to prevent valve float. I'll have to cross my fingers and hope it works.
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
Used roller cams
Tonight wasn't good, I had to clean my place.  But I'll plan for next Wednesday.
