Topic: hood spring removal (Read 1735 times) previous topic - next topic
hood spring removal
anybody know how to safely remove the springs on the 87-88 hoods? it looks like maybe pry the one part up over the part its resting on and slide it off, but i dont want it flinging off and braking anything, or myself.
hood spring removal
Collapse it after hood is off then wire tie it closed/shut then remove. It’s been a couple of years I think that’s what I did. Oyea when ting down be very very careful til its wired tied it could pop up and seriously injure you.
hood spring removal
We found another set, cut the springs off teh other set, then just removed the origional set from the hood(for my cowl hood).
1988- 3.8- T-bird- sold 2005 Grand Prix, GTP- COMP.G MODS: Inferno Hood, GXP spoiler, Liquid Metal Wheels,K&N Intake,LED taillights,LED reverse lights, LED interior lights, 180*,605s, Pacesetters :burnout:
hood spring removal
nate i can show u on tuesday
hood spring removal
anyways why remove them?  I thought they were better than having a prop rod in the way, but maybe you guys think differently.
hood spring removal
Quote from: 88turbo
Not on a fiberglass hood...
hood spring removal
They break a fiberglass hoods, mine was starting to crack under neath and the top was showing creases =:/ but for reg hoods their good.
hood spring removal
Pick up some 84-85 hood hinges
hood spring removal
i use them on my fiberglass hood  you just have to undo the little square clip and then you can move it up and down freely and use the arm as a hood prop
hood spring removal
I have a set of red un-sprung hinges that I took off of my Bird when I put on the sprung hinges I got from a junk yard.  If you want them I can ship them to you.  I think that just changing the entire hinge assembly would be much easier than trying to remove the spring.
