Topic: IRS in a fox bird???? test fit pics (Read 19432 times) previous topic - next topic
Reply #75
Thanks, but I'm well aware of the differences.  What I am asking is if anyone knows if the v6/GT brakes will physically bolt to the IRS assembly...
1988 Thunderbird Turbo Coupe
Reply #76
Quote from: booksix;230509
No...the mounting points for the brake brackets are on the rear uprights.
On the live axle cars, the mounting s that bolt to the axle housing are different between the V6/GT and Cobra set-ups.
You'd have to chop up the uprights to make the smaller brakes work.
Reply #77
Oh yeah, that makes sense.  So basically, there aren't removable s on the IRS like we have on the live axels.  So the s are built in...  this means all I need is to get a pair of loaded calipers with brackets (for a cobra), a set of rotors and I should be ready to bolt it all together...?
Reply #78
The rear calipers will bolt on, but that's about it.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
Reply #79
Any updates?
Reply #80
did you read the date on this? He has finished it.
