Topic: TC header pannel mod (Read 5412 times) previous topic - next topic
Re: TC header pannel mod
Quote from: oldraven
(here's me taking credit for something I thought of after someone else did it first :p )
Just goes to show great minds think alike
Quote from: Bird351
I'm thinking of modifying the grille on my '86 and making a floating Bird emblem in the center of it, and that's something I wouldn't mind making glow like that.
What about cuting a piece of electroluminescent sheet about 1/8" larger than the emblem, or whatever thickness you want to see.  Then cutting a piece of lexan to the same size and mount the electroluminescent sheet to the lexan to make the electroluminescent sheet more rigid.  And mount the emblem to that.
This shows one type of el sheet and how it can be cut however you want.  I have never used this stuff but plan to sometime as it has lots of possabilities.
http://www.beingseen.com/sheets.html
The other option that comes to mind would be to cut a piece of frosted lexan 1/8" larger than the emblem perimeter (or larger) and light it using leds mounted somewhere behind the emblem, so they are not seen.  This should be fairly easy using 3mm leds and the frosted lexan.  You may choose to paint the back of the lexan so no light would shine out the back.  Or use a piece of plexi mirror and frost it.  This already has an opaque back side and the mirror would help focus all the light where you want it.  This all makes since in my head but I am sure it may be confusing to try and follow what I have typed.
This is something I just did real quick to show what I meant by the 3mm leds and a piece of lexan.  I used 3mm white leds, and a piece of 1/4" plexi I had laying around.  I drilled into the inner circle using a .125" drill bit.  Then I frosted the plexi real quick just using 120grit on my random orbit sander.  Not a quality piece, it just shows what I meant.  Also I only put leds in half of the ring, since this was just for example.
Where did you get the lexan at?
you can go to most hobby shops and they have some, especially ones who sell r/c cars
