Topic: stripping door pillar? (Read 3340 times) previous topic - next topic
as for pressure washing the engine. i thought  a warm engine was bad to get wet. and what should i cover to keep from getting wet?
Go with the stripper without the glitter.  :tetas:  Everytime i go to wash my engine i don't worry about anything.  I've been doing that for years.  But if you want to be safe take a  plastic trash bag, or grocery bag and cover the alternator, and distributor.  that's about all that i'd worry about.
:pics-stfu:
 Project Thread with pics
took me a while but i finally got it. HA
Would this work for an 88?  I mean specificly the removal proceedure.  Mine are a little chipped, and I'd like to re-paint them.
88 TC, Lots of Mods.
should be think that they are done the same
Quote from: cougar86_89
I usually do it with a warm, but not hot engine.  The grease is easier to loosen up when it is warm.  If you use a steam pressure washer, then don't worry about that part.
As for getting stuff wet, I usually just go to town with the water.  But ordinarily, you should cover the distributor cap, alternator, and probably the main connector for the engine wiring harness near the firewall.
-John Fordham
1993 Cougar XR7 302 HO AOD
245,000 miles and still running strong
2005 F-150 FX4 SuperCab 5.4L
