Topic: roller rocker 1.60 or 1.70? (Read 5212 times) previous topic - next topic
What do we need to take in consideration for choosing within those?  :dunce:  :dunno:
Re: roller rocker 1.60 or 1.70?
Well you should consider what cam you are using in relation to what heads you are using, as well as what mods have been performed, also do you want a roller rocker or not, are the heads your using a pedestal mount or stud mount.
Tell us more about your motor.
Here's a partial list of the engine parts I'm interested in for my project....
Summit Parts #
- SUM-CSUM347KIT 347 Stroker Rebuild Kit (.030 overbore, Piston, Crank, Rods, Rings, gasket etc..)
- FMS-M12071-C302 Complete Engine Harness 1986-95EFI
- FMS-M6513A351   Valve Springs, Dual Springs, 289/302/351W, Set of 16
- CCA-851-16 Lifters, Hydraulic Roller, Ford/Lincoln/Mercury, Set of 16
- FMS-M6564A351   Roller Rocker Arms Alum 289/302/351W 1.60 Ratio 3/8 Stud Mount (or FMS-6564D351 1.70)
- FMS-M6250E303   Camshaft, Hydraulic Roller Tappet, Duration 282/282, Lift .498/.498
- FMS-M6565L302   Pushrods, Steel, 5/16 in. Diameter, 6.272 in. Length, Ball Ends, Hardened, Set of 16
If your using stock heads or e7's or something comparable in your setup I would have to say stick with the 1.6's.  The 1.7's will most likely be a clearance problem with that cam due to the good amount of advertised lift.  According to Ford,  Flat top pistons with E7 heads are good for .500 lift.  I have 1.7 rockers in my setup, however even with these I have about .485 lift.  With that cam I would ABSOLUTELY check your clearance as well.
Quote from: Paul Flockhart
With the E cam 1.7's should not be a problem. Im running that set up now in my car. Stock HO bottem end, ported E 7's.
The HO has Dish tops which means you can get away with more lift.  Forgot to mention that.  I just assumed Flat tops.  Sly, we would need to know more about the specific crank/rod/piston dimensions to give you a more accurate answer.
These Summit engine rotating kits are designed to help you get started on your engine the right way. The kits are configured to give you quality parts at a great price. They include a crankshaft, connecting rods, pistons, piston rings, rod and main bearings, gaskets, and a high volume oil pump.
Vendor Summit
Product Line  - Summit Engine Rotating Kits
Crankshaft Included - Yes
Crankshaft Material - Cast iron
Rear Main Seal Style -  2-piece
Balanced - No
Engine Balance - External
Balance Style - 28 oz. imbalance
Pistons Included - Yes
Piston Material - Hypereutectic aluminum
Piston Style  - Flat
Dome Volume (cc) - (Not Specified)
Dish Volume (cc) - 6.5
Valve Reliefs - Two
Wrist Pin Style - Floating
Piston Rings Included - Yes
Piston Ring Material - Chromemoly
Piston and Ring - Oversize (in) 0.030 in.
Piston and Ring - Oversize (mm) (Not Specified)
Connecting Rods Included - Yes
Connecting Rod Material - Forged 4340 steel
Connecting Rod Beam Style - H-beam
Rod Bearings Included - Yes
Main Bearings Included - Yes
Gaskets Included - Yes
Oil Pump Included - Yes
Oil Pump Style - Wet sump
Camshaft Included - No
Lifters Included - No
Timing Chain and Gears Included - Yes
Quantity - Sold as a kit.
What u r also saying is 1.7 will make more lift than 1.6?
Quote from: Sly1990
Yes, but the ratio of the rocker only effects LIft not duration.
Phil
Quote from: Sly1990
yep, you take the stock lift (.444" on HO's) and divide it by the stock ratio (1.6 on HO's), to get the lobe lift, in this case .2775". you then multiply that number by the new rocker ratio (1.7), and you get the new valve lift, .477".
Quote from: 88KSXR7
Phil
not quite true.
"Many people incorrectly assume that a change in rocker arm ratio has no effect on the duration the valves are open. In actuality there is some change to the duration at the valve depending on the lobe profile of the camshaft. Comp Cams explains that by lifting the valve an additional 7-8%, but beginning and ending the lift at the same point, the opening and closing rates become steeper. This increases duration, measured at the valve at 0.050" lift, by 1-2 degrees. You can measure the actual duration change by using a degree wheel and dial indicator set on the valve retainer. Coincidentally the principle of a steeper rate of opening and closing is what Comp Cams has engineered into their Extreme energy camshafts to enable more valve duration for a given lobe duration."
http://www.fordmuscle.com/archives/2001/10/rockerarms/
Thanks, this is very valuable info....  :ies:
If I understand correctly, 1.6:1 should be the best for me with the CAM I choosed... E303 has .498 lift so ill end up with .529 w/ 1.7:1... (piston-valve Clearance issue??)
Also 1.6 has less wear compared to the few HP gain i could get w/ 1.7....
well your quoted stuff from summit says the pistons are flat, but have 2 valve reliefs. I'd still check valve clearance regardless, you can never be too careful
Besides piston to valve clearence, you need to worry about spring bind also. Check with spring companys to see max lift on various springs. :ies:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
