Topic: Master Cylinder question (Read 2240 times) previous topic - next topic
I know this has been discussed before, but I am just trying to make sure  I get the right parts.  If I am using '96 Mustang brakes front and rear, then I should use an SN95 master cylinder since they were all designed to work together correct?  And of course an adjustable prop valve.
Matt :tg:
Anyone?
Matt :tg:
Its an '88 5.0 Sport.  Guess I should have mentioned that!
Matt :tg:
you can use the sn95, svo, or 93 corba master cylinder. i personally use an svo master cylinder with a 5.0 mustang brake booster.
So you have a V8.......isn't that cute.
Cool, I will use the SN95 because it fits into the budget better.
Matt :tg:
Hmm, cannot belive I never updated this.  The car has been running with '96 SN95 brakes frt and rear with 94-95 spindles up front with Maximum Motorsports C/C plates.  I am also running an SN95 master cylinder, and an adustable prop valve to the back.  The car stops ok, but I feel it could be better and am wondering if there is a better option for a booster.  I have a feeling that the booster was never replaced before I bought the car in '03, and I know I have never replaced it.  I am thinking about putting in an SN95 booster from a '94-95 GT or Cobra, because as far as I can tell, they both use the same booster.  Anyone have any thoughts on this?
Matt :tg:
