Topic: aftermarket hoods? (Read 2440 times) previous topic - next topic
aftermarket hoods?
where can i get a after market hood for my 88 cat? and i was told a tc hood with the vents will bolt on to my car is that true?
aftermarket hoods?
http://www.coolcats.net/stockmod/modified/hoods.html
Yes, that is true. It bolts up just fine. You will want to cap off the vents though. Unless you plan on using them for turbo/some kind of ram air setup.
2013 Focus (Daily)
1968 Cougar XR7
1987 Turbo Coupe
1988 Turbo Coupe (RIP)
aftermarket hoods?
I wanted to purchase TC hood, but was told that it would be non functional... I know someone has made a mod to make it functional, but is it even worth it...
aftermarket hoods?
Mines functional. It feeds the intercooler...
aftermarket hoods?
I don't think any aftermarket or stock scooped hood would be functional on a 5.0 or 3.8 without some creative induction work.
It's worth it if you think it is ;)
aftermarket hoods?
I was thinkin about getting one also but do you think I can reroute it to feed my intercooler or do you think that it would be easier, better and cheaper to just buy an intercooler fan or two?
aftermarket hoods?
hold up, of course its functional on a t/c.. im talkin abount making it functional on a non t/c v8.  i was just thinking that it would be pretty tight forming the duct work and then routing it on a 5.0 that is the part im wondering about.  An electric fan would probaly better easier in my opinion, but thats all it is - an opinion -
aftermarket hoods?
Once I get my TC hood, im gonna fab up a ram air. I have a cfi Cougar, which with the round style intake, should be alittle easier to make one, I'll do my dest to make it work.
aftermarket hoods?
i have an efi, mine would be a little harder i imagine
aftermarket hoods?
does any one have a pic of the under side of a tc hood? i think i have an idea!
t/c hood
X
its small .. but its there
aftermarket hoods?
The efi would have to use an intake like the cervini Stang hood. With the cfi Im just gonna run an "air box" over the distributor to the air cleaner, kinda like a Challenger or Cuda would have with the six pack, a plastic box like thing.  Im not so sure how to approach it yet, but we'll see.
aftermarket hoods?
Don't bother using the TC hood scoops for anything, they hardly do anything even on a TC, at lower speeds they actually flow air the WRONG way.  There is hardly anything to be gained with ram air anyway, compared to a normal cold air induction, at least at sane highway speeds.  The TC hood scoops are just a bad design, if you have a front mount IC you're better off with an extra fan running all the time.
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
