Topic: 11 inch front brakes-underway (Read 6347 times) previous topic - next topic
You might as well whip it out and soak the brake lines with your own piss, probably do a better job than the wd 40..  put some blaster on there!
regarding the brake lines... if you heat them up you will have to flush the entire system..  but you should do that anyway...
I use a line wrench with a pair of vise grips clamped down on them to prevent the wrench from spreading.
Mine were seized also. I used PB Blaster and vise grips. do not use a wrench. You'll strip the nuts for sure. Vise grips are your friend here ;)
actually combine the two tools..  place the line wrench on the fitting then clamp the vise grips on the line wrench jaws.  This little tip will allow you to remove any fitting..... well most of them!
Quote from: ThunderbirdSport302;90633
well, one snag right off....the fittings are frozen to the lines...i've been soaking the hell out of 'em with WD-40 (all ive got here right now)
if worse comes to worse, and they won't budge, i'll have to cut the lines, and re-flare them, although I'm not good at that...
Would it be safe to use some heat from a propane torch on it?...very carefully of course, i know how flammable brake fluid is!! :hick:
other than that, and the lack of brake pads till day after tomorrow, it's all but done...thanks guys...:D
Bring'er back...... What fitting did you wind up needing for the hard to soft lines?????
Mike
I can't remember right off...but if you want, I have a pair of nearly new front hoses for a the 11" brakes I'd sell...with the fittings needed...
Not much use for 'em with the SN95 setup I'm now using lol
Quote from: ThunderbirdSport302;359273
Lets do that.  PM me and we can set up a price or meeting point.
Quote from: Aerocoupe;359356
Just to loop these two threads together so the information is found easily:
http://www.foxtbirdcougarforums.com/showthread.php?31295-Finally-getting-something-done
Darren
Sorry I posted that up last night before you guys helped me out. :punchballs:
Mike
Thunderbirdsport302, I still want those hoses.
Mike
ok...I just now saw you'd PM'd..I'll dig 'em out tomorrow and get some pics for ya :)
Awesome, thank you.
Mike
Quote from: ThunderbirdSport302;359535
Did you find them yet?
Mike
If he can't find the hoses, I have a set, plus one new one.
Looks like Vinnie's in...I took mine off a few weeks ago, put them in a small box and *thought* I'd taken them out to my storage bin...but now they're AWOL.
Sorry that I dicked around your time...
Irony is....2 days after you get the ones from Vinnie, I'll find them. Ughh.
Quote from: ThunderbirdSport302;359804
Ive been getting dicked around by UPS on my struts.  They wont arrive till Mon.  I will wait if your lines are fairly new and have the fittings.  As long as you want to look for them. :bowdown:  What price are you thinking?;)
Mike
