Topic: my 1984 cougar lowrider (Read 15560 times) previous topic - next topic
Reply #60
im still alive! been busy with customers cars,but im getting back on mine now!!! im looking for some 351-w heads 69-71 casting# c90e-b or c90e-d, chamber size 60cc...
engine is 302. im shaving the firewall all holes in fenders will be welded up and smoothed as well and candy painted as well as the engine block
1984 MERCURY COUGAR "WINEFIRE"
sikkens candy winefire, shaved door handles, shaved antenna,3 hydraulics pumps,6 batteries,custom matched 100 spoke o.g. wires,hand engraved glass etching,2 tone vinly and tweed interior..
302 buildup in the works,and lots of chrome undercarriage
Reply #61
I've got a set of C9's from a 69 351W. Shipping might be expensive though. Where are you located. I'll see if I can get some pics up for you later on this week (I've gotta dig them out of the back corner of my garage).
Oh, and how much are you looking to spend?
Reply #62
Quote from: Dogcharmer;104619
im in wausau wisconsin,im looking for rebuilders that never been milled, im interested in buying them from you shipping i think would run about 60 bucks. get back to me. and thanks...
and for price what are they worth to you?? shiznit is that supposed to be said the other way around lol
Reply #63
These have never been milled that I know of. The 351 that they came off of is standard bore. I cant say that they're untouched because they have dual valve springs.
I'll get some pics for you by saturday and then I'll wrap one up and take it to the post office and find out what shipping would cost. Then I'll PM you and we can work out the details if ya still want them.
Reply #64
Quote from: Dogcharmer;104659
much appriciated! get back to me
Reply #65
Here are the pics. Sorry it took so long. They were buried pretty good so I've been putting off pulling them out. I cleaned off some of the grunge so you can actually see what they are and see the casting numbers.
Reply #66
Here's a couple more... and you have PM.
Reply #67
appriciate you diggin those out,i get paid this friday so depending on what ya want for em i should have the cash.....also i was wondering if you would know do you need a 351 w intake with these heads? or 302 beings the block is?....
Reply #68
302 intake is fine. The intake ports on the 351 heads are a little bigger than 302 heads but the water passages are exactly the same. The intake runners on a 302 intake will be a little smaller but thats generally true for most intake/head combos. Intake valves are 1.84 and the exhaust is the same as a 302.
The only thing you'll need to install them on a 302 is bushings for the head bolt holes. A 351 uses 1/2 bolts where as a 302 uses 7/16 so the bolt holes in the heads are obviously drilled for 351's. I think Trick Flow makes the bushings and there are probably alot of other sources for them.
Reply #69
Quote from: childforsaken;105470
i got your private message,i messaged you back,thanks my friend
Reply #71
dogcharmer what ya think about this package?
HYDRAULIC: Good for daily driven performance vehicles. Mid-range power. Slightly lower gears. Mild rough idle.
Camshaft Specification Table
Part Number 31-218-2
Engine 1963-1995 Ford
289ci-302ci
8cyl.
Grind Number  FS 268H-10
Description
  Intake Exhaust
Valve Adjustment 0  0
Gross Valve Lift 0.456  0.456
Duration At 0.006 Tappet Lift 268  268
Valve Timing At 0.006
  Open Close
Intake 28  60
Exhaust 68  20
These Specs Are For The Cam Installed At 106 Intake CL
  Intake Exhaust
Duration At 0.05  218  218
Lobe Lift 0.2853  0.2853
Lobe Separation 110
Recommended Valve Springs 942-16
whole kit$442.00 cam timing chain/gears valves etc.
new pics coming soon
Reply #72
mostly parts,shiznits going to come together fast so check back and TTT:punchballs:
Reply #73
Reply #74
